Sat 21 Apr 2018 - 12:55 by Z400
Project RockClod
Page 3 of 6 Previous  1, 2, 3, 4, 5, 6  Next
Re: Project RockClod
Post by Guest on Thu 31 May 2012 - 14:25
okay ladies!
found a body from the scx10 i had laying in a bin of parts.
Here it is in living color....
CLOD~HONCHO:
now onto fabbin a bed ontop the framerails...
Post by Jam Racing_1 on Thu 31 May 2012 - 18:50
eyes fooker
Post by Guest on Fri 1 Jun 2012 - 16:34
newest update:
DIG
using my micro servo from the trx 1/16 slash to pull the brush out from the rear motor. This way i can pull the rig in a real tight corner.
ordered the Honcho race cage from my LHS today to fit the body thats now on the chassis.
Post by Jam Racing_1 on Fri 1 Jun 2012 - 16:37
HUH ? ? ? ? ? ya lost me this time :swampy LMAO
Post by Guest on Fri 1 Jun 2012 - 16:57
by pulling the brush from the rear motor via the micro servo cuts power to that motor via 3CH and allows the rig to "DIG" cutting around xtreme corners when needed.
Post by Jam Racing_1 on Fri 1 Jun 2012 - 17:01
uuuuuuhhhh ok whatever works, nice cage setup. will be nice to see it out crawling soon fooker lol
Post by Guest on Fri 1 Jun 2012 - 17:23
change of plans....
i could do the brush setup but i will be using the micro servo ontop a platofrm i already have to control a switch on the negative side of the rear motor. this will be a clean install!
all i need is some time and drill holes throguh my center skidplate, mount up this raised platform, install the servo to it. From there the swiitch will be located directly under the servo. This will cut my power to the rear motor!
Post by Jam Racing_1 on Fri 1 Jun 2012 - 17:27
Well that is much cleaner and better than jerking the brush outta the holder, aint sure thats the best for the commutator either lol , :pix :pix :pix fooker lmao
Post by Guest on Fri 1 Jun 2012 - 18:00
okay....this is as far as i can get at this point, gotta run to work!
Bad pic but you get the idea so far!
switch will be mounted under the platform
Post by Jam Racing_1 on Fri 1 Jun 2012 - 18:11
Well good idea there swampy.... let us know how that works out fooker lol
Post by Guest on Sat 2 Jun 2012 - 4:37
after getting home from work....
tinkering with what i had here, i discovered that the micro servo sat nice and snug right under my platform. all i had to do is use zip ties to keep it in place for assurance!
goin through my box of clod & crawler shit, i also found the original power switch to hopefully use as my DIG switch. This is where maybe mike woud have an idea if it can handle the amperage from a 50-60+ turn motor?
Post by Jam Racing_1 on Sat 2 Jun 2012 - 11:02
I doubt the power / economy switch would handle that kinda power... after is just a cheep tamiya hard plastic switch lmao lmao I think maybe a metal cased switch from radio shack would be better. less chance of meltdown under high load....
Post by Guest on Sat 2 Jun 2012 - 11:21
i figured it was but thought id ask anyhow.
i seen my LHS had some switch but cant remember what
it was for? it was just as big as this economy switch.
i also have the "ground" wire desoldered from the motor and a length of 18g silicone wire from the motor which will reach the switch.
just need a switch!! :P
Post by Jam Racing_1 on Sat 2 Jun 2012 - 11:27
:pix :pix :pix
Post by Guest on Sat 2 Jun 2012 - 15:14
Here is a shot of the truck upside down to view the Deans and how it will be wired. The ends with no connectors will goto the 24v switch ill get come monday from RTS electronics
Post by Jam Racing_1 on Sat 2 Jun 2012 - 15:25
Nice :pix
Post by true2dz on Sat 2 Jun 2012 - 20:38
Nice ....
Post by Guest on Sun 3 Jun 2012 - 0:24
im callin this one E-DIG
everything is now ready except the 24v slide-switch ill grab hopefully on monday.
i also inverted the axles which would be a great idea but it looks fag
lMAO
im excited to see this thing crawl!
Post by Jam Racing_1 on Sun 3 Jun 2012 - 0:27
what no :pix on the inverted axles ?
Post by Guest on Sun 3 Jun 2012 - 0:56
just turn em around whereas the motors are sticking out from the front or rear.
gives you automatic BTA lol
i didnt like the looks myself
Post by true2dz on Sun 3 Jun 2012 - 2:07
Gettn closer huh cool
Post by Jam Racing_1 on Sun 3 Jun 2012 - 11:29
Close but no CIGAR !!!! lmao lmao lmao
Post by Guest on Sun 3 Jun 2012 - 13:20
was up lastnight til 2am....
stripped the clod down to bare-bone and threadlocked all nuts & bolts now that it functions how i want it. As you have noticed i have gone back to the piggyback shox as they give me far more then enuff articulation. Ive done a few mild mods to make those work as they were contacting the motor leads on articulation before.
Just waiting for the honcho racecage to install to the rearend.
then when i get the cash ill grab some nice 50t-60t motors.
Post by Jam Racing_1 on Sun 3 Jun 2012 - 13:55
damn is alot of work. hurry up fooker , I wanna eyes a vid lmao lmao lmao
Post by Guest on Sun 3 Jun 2012 - 15:33
Slapped a few new decals on the rig!
