» Mikes Navy pics
Sun 8 Sep 2013 - 17:06 by true2dz
Project RockClod
Page 1 of 6 1, 2, 3, 4, 5, 6  Next
Project RockClod
Post by Guest on Thu 3 May 2012 - 17:46
Well...here goes another project! lol
dug out what i could find for the old Clodbuster parts, and found alot of shit!
This will be a crawler using a 16.8v ESC on x2 Kyosho MagMayhem motors (9T)
and adjustable motor mounts by thundertech. Also have wheel widners ill have to dig
out somewhere also by Thundertech.
Lot #1
Stock chassis, custom chassis, MOA axles, links, partsbag, etc
Lot #2
Savage stock shox x4 (or) i have x4 alloy piggyback shocks (100mm)
x4 stock clod tires/wheels (or) i also have x4 stock wheels with nobby tires?
Some misc crawler items i still had kickin about:
Bumpers/scale
Links/ax10
Re: Project RockClod
Post by Guest on Thu 3 May 2012 - 21:09
Finished my custom TVP chassis for this Clod project...
Post by Jam Racing_1 on Thu 3 May 2012 - 21:48
Looks cool for a crawler chassis. but ya better keep in mind ya wanna have some weight also lol
Post by Guest on Thu 3 May 2012 - 21:55
thanks mike!
so far its working in my favor! lol
i removed the 3mm threadrod & 3/16" alloy tubing and opted for HPI savage alloy bars which evenly space this TVP now. Also gives me a platform to mount a plate ontop allowing for my electronics.
Post by Jam Racing_1 on Thu 3 May 2012 - 21:59
cool deal, try some kydex plastic or some acrylic to make ur mounts out of, will make nice electronics plate and comes in colors too lol we used blue acrylic on my WildFire truck
Post by Guest on Thu 3 May 2012 - 23:13
Here she is once again.....
AX10 lower links installed & the rest of the nuts&bolts have been threadlocked.
Post by Jam Racing_1 on Thu 3 May 2012 - 23:16
ur only gonna use 2 links per end ? whats gonna keep the axles from swaying and moving around ? ya need to triangulate them too .... got the axle tubes drilled yet ?
Post by Guest on Thu 3 May 2012 - 23:18
i know this! lol
i built a few crawlers.....
the triangulated links go from the top center of the axle to the top side of the TVPs (not made yet)
Post by Jam Racing_1 on Thu 3 May 2012 - 23:20
oic ok fooker, hope ya get it runnin soon lol
Post by Guest on Thu 3 May 2012 - 23:51
well.... started gettin the axles prepped for this rig....
before i head off to bed....
managed to get the axles stripped down to the bare-essentials! lol
ill need to repair the one axle up front as the support bar screw broke out from
the transcase. ooof! lol
tommorow after my LHS visit...ill be fabricating a 3-link post mount which will be installed
through the existing hole in the center/top of the axles (where the old bellcrank went).
Basically it will be x1 piece which will have x3 different mounting locations, a spacer to fill
the large hole in the transcase, x2 bolts, a spacer and a nut. Pretty simple design!
hard to explain, but ill post more as it unfolds!
Post by true2dz on Fri 4 May 2012 - 2:13
Looks like a nice project...
Post by Guest on Fri 4 May 2012 - 18:00
got the top deck installed along with the EVX2 16.8v waterproof ESC!
Post by true2dz on Sat 5 May 2012 - 16:49
ur gonna make mike JELOUS with a that sweet bling lol
Sweet project swamp dont put to much $$ in it cus ur prolly not gonna get wut ya put into it..
Post by Guest on Sat 5 May 2012 - 18:29
found some axial standoffs for my bodymounts!
the alloy i used was too soft and kept moving around, so these
are solid!
ill be working on the 3-link postmounts later aswel as mounting up the lower links to the axles.
Post by Guest on Sat 5 May 2012 - 21:14
got too the axles/configuration...
possiblly as seen, but might use longer shocks yet??
i just love my alloy threaded piggybacks.. lol
just to give you an idea how this will come together mike! :P
keepin in mind i still havent fabb'd the 3-link post mounts yet.
Post by Jam Racing_1 on Sat 5 May 2012 - 22:13
Well have fun with it, even tho ya prolly never drive it. but if ya do remember it aint ur daddys savage lmao
Post by Guest on Sat 5 May 2012 - 22:27
im thinkin ill prob ending up giving it too one of my boys as i have no use for it. itll be slow (crawler) so perfect for a starter! :D
Post by Guest on Sun 6 May 2012 - 2:12
Custom lower-link mounts for Clod axles
Template from Styrene.
Post by Guest on Sun 6 May 2012 - 12:55
TEMPLATE
3-Link Post Mount
Here's the general design for my mount, still a little trimming to
do to make it look right but this is pretty much it.
A spacer will run through the hole in the axle and up into this custom
mount which is followed by a 3mm machine screw.
LOWER AXLE MOUNTS:
Post by Guest on Sat 12 May 2012 - 2:24
Rising from the fucking ashes comes RockClod
Finally got to the lower axle mounts using alloy, now atleast this rig is taking shape!
Post by true2dz on Sat 12 May 2012 - 2:37
Sweet rig swamp goodjob fooker .How much twist can ya git ?
Post by Jam Racing_1 on Sat 12 May 2012 - 15:42
WildFire will twist like a MOFO and can crawl as well as race lmao
Nice :pix so far :swampy but them lower mounts look a lil thin there, maybe is the angle of the :pix hope it worx out fooker
Post by Guest on Sat 12 May 2012 - 16:08
the mounts are solid, cutting was a fuckin whore! lol
Thundertech wheel widners and big nobby tires installed, all the lower end stuff is finished (spacers, screrws, nuts, threadlocked, etc...) Still need something 10mm thick to fabricate my custom 3-link post mounts. Just cant seem to find anything with this thickness??
Post by Guest on Sat 12 May 2012 - 23:15
Dropped on my old Clod body (this is the larger scale lexan from ProLine)
and cut er up!
Post by Jam Racing_1 on Sat 12 May 2012 - 23:19
cool startin to eyes like a truck now, lol
