Project nitro to electic TC3
Post by Guest on Mon 29 Aug 2011 - 0:56
just got my fleet together and decided to continue my conversion on the TC3
for the most part the nitro shit has been stripped and the geartrain ready for electrics.
Just need to mount a motor, electrics and whatnot, but this will be using a Pitch like the clodbuster
uses for the spur and pinion.
The Fleet so far...
Re: Project nitro to electic TC3
Post by Guest on Mon 29 Aug 2011 - 11:38
Electric version
heres the AFTER pic, whereas the 2nd speed has been removed and one-way CA glued permanently.
BEFORE pic, as a Nitro model.
Post by Jam Racing_1 on Mon 29 Aug 2011 - 17:45
Sweet, ya gonna go brushless with it. Look at Tekin esc and motor setups. lil expensive but they have a great reputation.....
Post by true2dz on Tue 30 Aug 2011 - 2:36
cool fleet swamp' git lots of :pix sweet roller man!
Post by Guest on Tue 30 Aug 2011 - 10:06
messes around with it quickly and decided to use stiff coilovers (yellow) and will be
sticking with the TE37's on Race slicks (red).
Post by Guest on Tue 30 Aug 2011 - 12:29
after digging through bin after bin.....
found all the pieces needed to get this to RTR status.
AE TR202A 2-CH AM Rx
Axial NVS (night vision system)
HPI SF-1 servo
Motor not decided (motor shown in image only for fitment)
ESC - Undecided
6-cell stickpack by Venom
AE XP2 2-CH AM Tx
*Im thinking on using my brushless setup off the Slash (VXL3M)?
After looking around...i found this shell ill be ordering sometime soon (De Tamaso Pantera)
Post by true2dz on Tue 30 Aug 2011 - 18:04
Almost dun i see, and the new lid looks great goodjob fooker
Post by Guest on Wed 31 Aug 2011 - 12:44
update:
this one has come to a pause for now as i had to order the top deck where the servo mounts to. I was going to use a spare servo-mount from the Axial SCX10 which could have worked if there wasnt a big hole in the chassis, because of it i cannot mount anything directly to the chassis. As for the motor i still need to fabricate a mount which i had an old AE buggy motor mount but cant find it for some reason?
ill post anything new as they come about.
Post by Jam Racing_1 on Wed 31 Aug 2011 - 17:15
Well so far with the componets sitting on there looks ok. maybe ya should just get a used electric tc3 off the bay and start with an electric chassis setup, would make ur life a lil easier in the long run.....
Maybe these :pix will help ya with ur conversion....
Post by Guest on Wed 31 Aug 2011 - 18:14
i had the ETC3 years ago and still have the manual for it, so its all cool i know what im doing and what i need/want for this set up. The reason i dont want another ETC3 is i just didnt care for it at all. And with the NTC3 i am left with a SOLID chassis, stiffer suspension and its a bit heavier which ill need when i decide to go 1/8th brushless in this bitch. Shell be WAY to fast throwing the light ETC3 into the field. lol
i need the additional weight on this soon to be speed rocket, but i appreciate the help Mike! :D
